When I optistruct the model there is no errors ,but a component of the model has flew away,and the stress value is very big.What can I do ?
Thank you!!
Hi spring
Check if you had constrained the model properly. This could be one of the reasons in your case.
I have checked the constraints, there is no problem.
spring
Can you check the magnitudes of forces/moments applied in your model, maybe that is causing the model fly away?
you can share the model with us, if you still face the problem.
use the dropbox link in my signature to share the model.
I have sent it to you!
