Vertical Displacement for Rotational Force
Altair Forum User
Altair Forum User
edited November 2020 in Community Q&A
I am running a rotational analysis using the RFORCE Card, and keep getting significant vertical displacement instead of displacement in the radial direction, which doesn't make sense. I should be getting the largest displacement in my radial direction. I have been trying to figure it out for days without luck. I have attached the file for reference.
Welcome!
  • tinh
    tinh Altair Community Member
    edited March 2017
    I think the blade is bended due to RFORCE, so z-disp is higher than radia-disp
  • Altair Forum User
    Altair Forum User
    edited March 2017
    @tinh you say it's bent due to RFORCE, so is my rotational axis wrong? i think i've defined R1, R2, and R3 correctly, which should give me the most displacement in the radial direction.
  • tinh
    edited March 2017
    No no @sch, your axis is OK
    It is due to your structure. If it is a simple bar like image (1) , there is only radial disp
    but I think your structure is similar to (2), so when it rotates, it's bended, then axial disp is higher
  • Altair Forum User
    Altair Forum User
    edited March 2017
    @sch
    I think @tinh is correct. Due to offset some moment is created and this is very high compared to radial displacement.
Welcome!
Welcome!
