Problem with disk space!!!
Altair Forum User
Altair Forum User
Hi. I have a problem with disk space. What can I do ??? I use parameters
 2 PARAM(s) were set:
    CHECKEL,NO
    HASHASSM,YES
** WARNING # 1971
 Current run is likely to fail due to insufficient disk space.
 Estimated disk space requirement = 222019 MB
 Estimated disk space available = 107723 MB
  Suggestions to reduce disk space requirements:
 For static analysis - reduce the number of loadcases.
 For eigenvalue/buckling analysis - reduce frequency range in
 EIGRL card or number of modes requested.
 For FRF analysis - reduce the number of loading frequencies.
 For transient analysis - reduce the number of output time steps.
ITERATION   0
 *** ERROR # 158 ***
 Error encountered when accessing the scratch file.
    error from subroutine xdslsv
    Solver error no. =   -702
 This may be caused by insufficient disk space or some other
 system resource related limitations.
 Try one or more of the following workarounds if you think otherwise
 and if this issue happens on Windows.
 - Resubmit a job.
 - Avoid writing scratch files in the drive where the Operating System is
   installed (start the job on other drive or use TMPDIR/-tmpdir options).
 - Disable real time protection at minimum for files with extension rs~ .
 - Use of environment variable OS_SCRATCH_EXT=txt may help.
 This error was detected in subroutine statslv.
 This error occurs in module 'lstatdrv'.
  • Q.Nguyen-Dai
    Q.Nguyen-Dai Altair Community Member
    edited April 2019
    You need a new hard disk :P/emoticons/default_tongue.png' srcset='/emoticons/tongue@2x.png 2x' title=':P' width='20' />
  • Altair Forum User
    Altair Forum User
    edited April 2019
    This is just one solution to buy a new hard disk? :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20' />
  • robert1024
    robert1024 Altair Community Member
    edited September 2019
    Hi. I have the same problem. Have you any solution ??? I don't want to buy new disk.
     *** WARNING # 1970
     Current run may fail due to insufficient disk space.
     Estimated disk space requirement = 411671 MB
     Estimated disk space available = 218908 MB
     *** ERROR # 7004 ***
     Not enough working storage for numerical factorization
     The run failed because automatic memory expansion has failed.
     Please see the previous error message for more information.
  • Rahul Rajan_21763
    Rahul Rajan_21763 New Altair Community Member
    Are you requesting output for all nodes? If so ,then please request output for SET.
