Laminate two different components
Hugo Padilla
Hugo Padilla New Altair Community Member
edited January 2022 in Community Q&A
I´m trying to laminate a rim of two components, where, both parts use the same PCOMPP property but different laminates: laminate_1 for top part and laminate_2 for bottom part and interface_lamint for the laminates mentioned before.
The problem is that it only works for one laminate, I can see the plies of laminate_1. (see next photo)image
How could I fix this?
Thanks
  • Adriano_Koga
    Adriano_Koga
    edited January 2022
    there should not be an issue with your modeling.
    Can you try this attached model?
  • Hugo Padilla
    edited January 2022
    Hi again,
    I have been working on it, but I haven´t fixed the problem yet. This happens when trying with different laminate options:
    If I use ply laminates, both laminations are created but separately (see photo)image
    and if I use sublaminate and interface laminate, it is only one lamination created and separated from the "mold" also.(see photo)image
    I´m new in Altair and I don´t understand why does this happen... What should I do?
    Thanks.
Welcome!
Welcome!
