I am performing FRF analysis of an overhang part mounted on engine.
From testing, I requested following vibration data at mounting and at tip-
1) G vs RPM (sweep up) - from this I got to know at which RPM, G value is maximum due to resonance.
2)FFT data (G vs Freq) at that single RPM where G was maximum while sweep up.
Now, my query is ...from FFt data, my maximum G value at particular frequency is less than 1G .
But from sweep up data (G vs RPM), if I check G value at that RPM , then it is more than 3G.
So, Now For FRF analysis in CAE, which G value I should take for excitation input (from FFT or from sweep up).
How to correlate max. displacement and acceleration plotted at tip in CAE with testing.
Thanks in advance.
