Dear Mr. Grasmannsdorf,
I would like to ask how to define Revolute Joints for an FE Analysis with OptiStruct. I modelled a Shaft which should be constrained in a mounting, except for the revolution around the shaft axis. What would be the appropriate way to model this constraint?
I used two Rigid Spiders within the shaft and mounting and a revolute joint to connect the rigids. However in simulation the model seems to be unconstrained and is not kept at its location. What do I need to consider when modelling revolute joints or how else could I model the desired constraint?
Mit freundlichen Grüßen
