displacement negative value
hi,
when i requested displacement as output in frequency response analysis and acceleration as output in random vibration analysis some of the values has negative displacement and negative g values i.e acceleration psd .what does the negative values means . i gave type as both for RRA
Ok . Can u pls tell me the reason for negative values of psd in random vibration analysis. will the output of RRA will be in psd only??
0 -
Can you share model files and result files?
0 -
this is acceleration output file .and the model id human body which contains about 3 lakh elements
0 -
As said in a previous reply, the nodes displaced in negative directional component.
586 9.07577E-03-4.36800E-02 1.37167E+00 0.00000E+00 0.00000E+00 0.00000E+00
The above node for instance has a negative Y displacement.
0 -
Hi sir,
it is the output of acceleration when i gave psd as input. ouput of psd can't be negative . if we give acceleration as output will it give in terms of g or g/Hz?
0 -
when i give psd as input will the output also be psd only??
