The problem consists of a connecting rod submitted to axial loads which define the phases of admission (traction) and combustion (compression).
I am trying to run the following optimization:
- 2 load steps :
- linear static (traction)
- linear static (compression)
- 2 responses :
- 1 constraint :
- 1 objective :
Without combining the two load steps, I managed to run the optimization.
I couldn't find a way integrating the two load steps for the optimization. I found that the only time that I can include the load step is when I define the objective. However only one load step can be selected. Therefore I was wondering if there is a way to integrate both of the load steps mentioned earlier.
Thank you !
