Hi all there
I have a question which I would like to ask you about how to solve.
Problem: create an analyzing model (3 layers model) by using prop/type22 and calculate it. Then compare the result with the result of prop/solid/1
for example: A model which have 3 layers (sandwich layer) have the detail as follow:
t1 = 0.1, Young modulus1 = 3000 MPa
t2 = 0.8, Young modulus2 = 20000 MPa
t3 = 0.1, Young modulus3 = 3000 MPa
and calculate 2 cases (the result should be the same)
case 1: use prop/type22 to set 3 layer one
case 2: use prop/solid/1 and use the mean value of young modulus = 11700 MPa
thank you in advance!
