Hi, I designed microstrip inset feed patch antenna but its reflection ceofficient changes with respect to frequency interval selection . Below, there are 3 different frequency interval for the same design paramaters.
Which parameter give me best results in fabrication or is there exist a rule to select frequecny interval to design antenna? What is the reason that cause this difference.
