Hey, while my optimization no command file had been created.
How do i have to set the settings that one is created?
Do i have to put the export options to all?
greets
Run options should be set to optimization.
jeah shure, i made a topology optimization wth this run option an optimization, but no command file was created!!
push!
Could you please share the .fem file to take a quick look?
yes, the files are here.
thank you for your help!
in These Pictures you can see the files i Need and the files i have
i already try it again and again but These files i Need are not createtd eithjer i can choose the Option command file....
The above shared .fem file runs fine at my end. Results are saved in the .h3d file for optimization & .out file will help to get warnings and errors.
Why you want command file & what exactly you are looking for?
yeah everything runs fine, but i Need the command file to rebuild the model shown in the Picture below
push!!!
From v17 cmf file is replaced by tcl file,
Invoke menu Run >Tcl/Tk Script
From v17 cmf file is replaced by tcl file, Invoke menu Run >Tcl/Tk Script
okay but when i run this, there is an error...
Activate hm window before running
