Hello Sir
I have a problem with the peak forces in the model. It had 3 boxes of different length crushed by the wall during the crushing i had got the required peak force for the first box but after the 30 mm from starting from the crushing of first box there is the another box placed which has to be show the peak force more than the first one also the same for the third box. But i had got the results that has not very much increase in the peak force at second and the third stage that it has to be. should it required to be constrained at different positions? the following picture shows the results that i must get. these are the results for the similar model that i am working on but i cant able to get those results.please help......
<?xml version="1.0" encoding="UTF-8"?>.thumb.jpg.2bef1ffbb50db95fb0abdd1a49184c7d.jpg)
