* RUN KILLED : TOTAL MASS ERROR LIMIT REACHED ?
What to do ?
Check the imposed time step in the model. It seem likes the imposed time step value is very high.
Reduce the value and try running again.
i did that and but renaming time is increasing .What can be the reason ?
This seems like the time step of the model is decreasing and so the run time is increasing. Check the model for any penetrations/intersections which could result in time step drop.
From the engine out (_0001.out) file check which object is responsible for the low time step. It can be an element, a node or an interface.
Is it anyway dependent on direction of loading ?
No, but if the loading direction is not correct it could result in weird model behavior which could result in element distortion.
Can you please share the engine out (_0001.out) file.
