fct_IDp for Mat LAW 36
Altair Forum User
Altair Forum User
I'd like to model an elasto-plastic material with a softening and stiffening region. This material behaves differently in compression and tension, thus I would like to input a fct_IDp for Mat LAW 36. Is there an example on how to define this pressure dependent function?
Thanks for the help
Welcome!
  • Altair Forum User
    Altair Forum User
    edited September 2018
    Hi @Marie
    There is sample table for LAW 36 RADIOSS help. Please check the same:
    #RADIOSS STARTER
    /UNIT/1
    unit for mat
                       g                  mm                  ms
    #-  2. MATERIALS:
    /MAT/PLAS_TAB/1/1
    Aluminium_example
    #              RHO_I
                   .0027                   0
    #                  E                  Nu           Eps_p_max               Eps_t               Eps_m
                   60400                 .33                   0                   0                   0
    #  N_funct  F_smooth              C_hard               F_cut               Eps_f                  VP
            14         0                   0                   0                   0                   0
    #  fct_IDp              Fscale   Fct_IDE                EInf                  CE
             0                   0         0                   0                   0
    # func_ID1  func_ID2  func_ID3  func_ID4  func_ID5
             1         2         3         4         5
             6         7         8         9        10
            11        12        13        14
    #           Fscale_1            Fscale_2            Fscale_3            Fscale_4            Fscale_5
                       1                 1.2                 1.4                 1.6                 1.9
                      10                10.2                10.4                10.6                10.9
                      20                20.2                20.4                20.6
    #          Eps_dot_1           Eps_dot_2           Eps_dot_3           Eps_dot_4           Eps_dot_5
                       0                  20                  30                  40                  50
                     110                 120                 130                 140                 150
                     210                 220                 230                 240
    #-  3. FUNCTIONS:
    /FUNCT/1
    function_36
    #                  X                   Y
                       0                  90
                  2.5E-4                 100
                    .001                 104
                    .009                 121
                    .017                 136
                    .021                 143
                    .036                 156
                    .045                 162
                    .055                 165
                    .072                 170
                    .075                 170
    /FUNCT/2
    function_36
    #                  X                   Y
                       0                  90
                  2.5E-4                 100
                    .001                 104
                    .009                 121
                    .017                 136
                    .021                 143
                    .036                 156
                    .045                 162
                    .055                 165
                    .072                 170
                    .075                 170
    /FUNCT/3
    function_36
    #                  X                   Y
                       0                  90
                  2.5E-4                 100
                    .001                 104
                    .009                 121
                    .017                 136
                    .021                 143
                    .036                 156
                    .045                 162
                    .055                 165
                    .072                 170
                    .075                 170
    /FUNCT/4
    function_36
    #                  X                   Y
                       0                  90
                  2.5E-4                 100
                    .001                 104
                    .009                 121
                    .017                 136
                    .021                 143
                    .036                 156
                    .045                 162
                    .055                 165
                    .072                 170
                    .075                 170
    /FUNCT/5
    function_36
    #                  X                   Y
                       0                  90
                  2.5E-4                 100
                    .001                 104
                    .009                 121
                    .017                 136
                    .021                 143
                    .036                 156
                    .045                 162
                    .055                 165
                    .072                 170
                    .075                 170
    /FUNCT/6
    function_36
    #                  X                   Y
                       0                  90
                  2.5E-4                 100
                    .001                 104
                    .009                 121
                    .017                 136
                    .021                 143
                    .036                 156
                    .045                 162
                    .055                 165
                    .072                 170
                    .075                 170
    /FUNCT/7
    function_36
    #                  X                   Y
                       0                  90
                  2.5E-4                 100
                    .001                 104
                    .009                 121
                    .017                 136
                    .021                 143
                    .036                 156
                    .045                 162
                    .055                 165
                    .072                 170
                    .075                 170
    /FUNCT/8
    function_36
    #                  X                   Y
                       0                  90
                  2.5E-4                 100
                    .001                 104
                    .009                 121
                    .017                 136
                    .021                 143
                    .036                 156
                    .045                 162
                    .055                 165
                    .072                 170
                    .075                 170
    /FUNCT/9
    function_36
    #                  X                   Y
                       0                  90
                  2.5E-4                 100
                    .001                 104
                    .009                 121
                    .017                 136
                    .021                 143
                    .036                 156
                    .045                 162
                    .055                 165
                    .072                 170
                    .075                 170
    /FUNCT/10
    function_36
    #                  X                   Y
                       0                  90
                  2.5E-4                 100
                    .001                 104
                    .009                 121
                    .017                 136
                    .021                 143
                    .036                 156
                    .045                 162
                    .055                 165
                    .072                 170
                    .075                 170
    /FUNCT/11
    function_36
    #                  X                   Y
                       0                  90
                  2.5E-4                 100
                    .001                 104
                    .009                 121
                    .017                 136
                    .021                 143
                    .036                 156
                    .045                 162
                    .055                 165
                    .072                 170
                    .075                 170
    /FUNCT/12
    function_36
    #                  X                   Y
                       0                  90
                  2.5E-4                 100
                    .001                 104
                    .009                 121
                    .017                 136
                    .021                 143
                    .036                 156
                    .045                 162
                    .055                 165
                    .072                 170
                    .075                 170
    /FUNCT/13
    function_36
    #                  X                   Y
                       0                  90
                  2.5E-4                 100
                    .001                 104
                    .009                 121
                    .017                 136
                    .021                 143
                    .036                 156
                    .045                 162
                    .055                 165
                    .072                 170
                    .075                 170
    /FUNCT/14
    function_36
    #                  X                   Y
                       0                  90
                  2.5E-4                 100
                    .001                 104
                    .009                 121
                    .017                 136
                    .021                 143
                    .036                 156
                    .045                 162
                    .055                 165
                    .072                 170
                    .075                 170
    #ENDDATA
    /END
  • Altair Forum User
    Altair Forum User
    Hi Prakash,
    thanks, but I was looking for a specific example using the pressure dependent function fct_IDp.
    I only have the stress-strain functions of the material for compression and tension and I do not know how to calculate the pressure function based on them
  • Altair Forum User
    Altair Forum User
    Hi @Marie
    If you have Stress Vs Strain curve, you can use Fct_ID1
  • Altair Forum User
    Altair Forum User
    Hi Prakash,
    my material behaves differently in compression and tension, so how can I model this?
  • Altair Forum User
    Altair Forum User
    Hi @Marie
    Please check LAW 66, This law models an isotropic tension-compression elasto-plastic material law using user-defined functions
  • Altair Forum User
    Altair Forum User
    Hi Prakash,
    I will check it, thanks
  • Altair Forum User
    Altair Forum User
    is it correct that the values in the compression and tension yield stress curves of MAT LAW 66 are true stress and true strain?
  • Altair Forum User
    Altair Forum User
    HI,
    Yes, most of the materials law use True stress-strain curve except LAW 42
Welcome!
Welcome!
