Sir,
I need an inflated airbag model without showing the deployment. It should have the material properties and property card similar to airbag but the infation should be constant. So can I use monvol-gas for the same purpose. Or is it incorrect to use airbag material and properties without defining the injectors,Vents and mass flow curves
