Hi experts,
- I am using AcuSolve to make a simulation of wind turbine.
The concept is a wind turbine standing on the ground and subject to a wind speed at 5 m/s.
The wind make the rotor rotate around its axis.
- I used transient simulation with sliding mesh approach (like in tutorial Acu-T 5001) and the mesh motion is rigid-body-dynamic.
But my simulation stopped after 31 time steps while the settings was 100 time steps.
- Acutails show error as below:
- Can you give me any advice about this issue?
- The acusolve database can be download from this link:
https://drive.google.com/open?id=18Q7m8_dtrlO39iBF1YqfNC8QTS5kd6CB
(meshing done by HyperMesh and imported into AcuConsole for setup the problem)
Thank you very much!
