Hello.
When I am meshing 1D in Hypermesh sometimes the mesh moves to other side. It does not allow me to sew the mesh with other elements. Also, when I try to remove all these elements that have been moved I can not select all them using a window. If I want to mask them, I must select them in the meshing position, not in the translation position.
It is not the first time it happens, and it means a problem to finish my work at time. Please, does someone know what is the problem?
Thank you. Regards,
Rubén Molina.
