Altair RISE
Nominate Yourself Now!
Meshing problems - The mesh moves
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello.
When I am meshing 1D in Hypermesh sometimes the mesh moves to other side. It does not allow me to sew the mesh with other elements. Also, when I try to remove all these elements that have been moved I can not select all them using a window. If I want to mask them, I must select them in the meshing position, not in the translation position.
It is not the first time it happens, and it means a problem to finish my work at time. Please, does someone know what is the problem?
Thank you. Regards,
Rubén Molina.
1 - 8 of 81
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Pls take a video clip and show what you did.
    Altair Employee
    OP
    I can not take a video clip, but I will try to explain you with these 3 images.
    The first one shows us the elements when I open Hypermesh and I isolate this mesh. The second one shows us the same but when I click the button framing in red to show the 1D elements in 3 dimensions. The last one shows us the same that the first one but clicking other time the same button.
    I can see this behaviour appearing when I modify one of the elements of the 1D mesh (how you can see, I deleted some elements in the 1D mesh before taking the images).
    <?xml version="1.0" encoding="UTF-8"?>CONJUNTO_fallo.hm - HyperMesh 2017.1 - OptiStruct.jpg
    <?xml version="1.0" encoding="UTF-8"?>CONJUNTO_fallo.hm - HyperMesh 2017.1 - OptiStruct_2.jpg
    <?xml version="1.0" encoding="UTF-8"?>CONJUNTO_fallo.hm - HyperMesh 2017.1 - OptiStruct_3.jpg
    User: "tinh"
    Updated by tinh
    Assign beam section to 1d elems and recheck.
    If no section assigned, sometimes graphic becomes abnormal.
    Altair Employee
    OP
    I did it, but it continues working like I shew.
    User: "tinh"
    Updated by tinh
    Do you see beam shape when select 3d representation?
    Altair Employee
    OP
    Yes, I do. At the moment I am meshing other time my model, but it is also happening there.
    I am meshing a wing's rib with 1D elements to create rib's flanges, but just when I mesh the last one all the other move to other side like this.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.8ba3923760d8eba53ef12639e170d289.png
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.dbe25bba8f185d2ed5122f3cacc2bd3d.png
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.f000657ec0e9c0b7de0173e75947220a.png
    There are no reasons to happen, therefor I think that it is a software problem.
    User: "tinh"
    Updated by tinh
    Did you check the beam's offsets?
    Altair Employee
    OP
    Yes, I checked them. There aren't any offsets.
