Meshing problems - The mesh moves
Hello.
When I am meshing 1D in Hypermesh sometimes the mesh moves to other side. It does not allow me to sew the mesh with other elements. Also, when I try to remove all these elements that have been moved I can not select all them using a window. If I want to mask them, I must select them in the meshing position, not in the translation position.
It is not the first time it happens, and it means a problem to finish my work at time. Please, does someone know what is the problem?
Thank you. Regards,
Rubén Molina.
I can not take a video clip, but I will try to explain you with these 3 images.
The first one shows us the elements when I open Hypermesh and I isolate this mesh. The second one shows us the same but when I click the button framing in red to show the 1D elements in 3 dimensions. The last one shows us the same that the first one but clicking other time the same button.
I can see this behaviour appearing when I modify one of the elements of the 1D mesh (how you can see, I deleted some elements in the 1D mesh before taking the images).
<?xml version="1.0" encoding="UTF-8"?>![]()
Yes, I do. At the moment I am meshing other time my model, but it is also happening there.
I am meshing a wing's rib with 1D elements to create rib's flanges, but just when I mesh the last one all the other move to other side like this.
There are no reasons to happen, therefor I think that it is a software problem.
Pls take a video clip and show what you did.
