fatigue life
Altair Forum User
Altair Forum User
hello, i am a student who started to use optistruct to do fatigue analysis. Regarding to the fatigue analysis of optistruct, there are two results  will display which are fatigue damage and fatigue life. As i read in the previous altair forum , it stated that hyperwork use miner's rule. So, my question is what is the result of fatigue life from the optistruct represent for? thank you
Welcome!
  • Altair Forum User
    Altair Forum User
    edited October 2018
    Hi @amin96
    Fatigue life gives an idea of how long the material will last before failure due to cyclic loading.
  • Altair Forum User
    Altair Forum User
    edited October 2018
    from what i have done, the value of fatigue damage is above 1 and the fatigue life is 1xe-4. i have read another altair forum which stated that if the value of fatigue damage is above 1 then the design is considered as a failure. so, does that mean my design is a failure?
    regarding to the value of fatigue life above, does that mean my design will be failure even one cycle is not completed?
    thank you
  • Altair Forum User
    Altair Forum User
    edited October 2018
    Can you check the SN curve?
    If the SN curve is fine, Please add DEBUG,DEFAULT,2 and try again?
  • Altair Forum User
    Altair Forum User
    edited October 2018
    may i know how to create SN curve using Hypergraph? if possible, i also want to know rainflow diagram.
    thank you
  • Altair Forum User
    Altair Forum User
    edited October 2018
    use RNFLOW to output rainflow cycle count.
Welcome!
Welcome!
