Hi all,
I am performing a shaft buckling analysis by applying a higher load in Implicit solver. Shaft can able to withstand load of 1/4 th of the applied load, due to element distortion can't able to apply the full load. I am interested to know the behavior of shaft at the higher load. Is it possible to do the same analysis in Radioss to withstand the higher load (mainly to avoid element distortion)?
