I am using HyperWorks for the first time and I did create a plate with a composite laminate. I want to know how can I read its elactic modulus in the third direction ?
Thank you for your help !
Hi @itouila
Is it shell elements or solid elements.
If you are using OptiStruct user profile, use MAT9ORT which is compatible with solid elements.
