Hi there,
I could not find anything to this topic, so I started a new thread.
I am trying to constrain certain nodes of my modelthat allows for example a displacement in x-direction in a certain range, let's say -10mm to 10mm from it's initial position. Just like a slide bearing with end stops. I attached a screenshot for further explanation.
I could not find any options in the BCS_Collector. There, I was just able to constrain the directions fully. Is there a simple possibility to acchieve this or do I have to model some sort of end stop. I would be very thankful, if someone could give me a hint!
Greetings!
