Error ID 639
I ran a very basic analysis. Component A rotates about a vertical spindle. I gave a initial velocity around vertical axis and i constrained bottom end of spindle.
I changed the initial velocity around axis's SKEW to FRAME through card editor (found that from your previous discussion)
Where should i check for this error ID(639).. Basically if an error arises where should i seek for help.
.. BLOCK FREE FORMAT
.. STARTER RUNNING ON 1 THREAD
.. CONTROL VARIABLES
.. UNITS SYSTEM
.. MATERIALS
.. NODES
.. PROPERTIES
.. 3D SOLID ELEMENTS
.. SUBSETS
.. ELEMENT GROUPS
.. PART GROUPS
.. NODE GROUP
.. BOUNDARY CONDITIONS
.. INITIAL VELOCITIES
.. DOMAIN DECOMPOSITION
.. ELEMENT GROUPS
ERROR ID : 639
** ERROR IN INPUT CONSISTENCY
ERROR ID : 639
ERROR ID : 639
ERROR ID : 639
.. RIGID BODIES
.. ELEMENT BUFFER INITIALIZATION
WARNING ID : 312
** INCOMPATIBLE KINEMATIC CONDITIONS IN MODEL
DESCRIPTION :
126 INCOMPATIBLE KINEMATIC CONDITIONS IN MODEL
.. GEOMETRY PLOT FILE
.. ERROR ==> NO RESTART FILE
ERROR TERMINATION
4 ERROR(S)
2 WARNING(S)
PLEASE CHECK LISTING FILE FOR FURTHER DETAILS
==== End of solver screen output ====
==== Job completed ====
Hi Sundaram,
The problem is with the penta elements.
PENTA6 is somehow causing the problem and update penta element type to PENTA6DG.
Please update the elements (2D panel>Element Types) and try running the file.
If errors arise you should first search the forum (at the top right).
You could also do a google search using syntax: keywords site:forum.altair.com
