Static Analysis using Opti struct
Altair Forum User
Even my model is properly constrained, the displacement is showing like e^10.
What could be the possible error in that? Model doesn't have any free edges, temp nodes, all the material data are correct.
The constrained is applied to the independent node of the Rbe2 created (at all bolt locations)
Thanks in Advance.
Thanks,
Arun /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
Hi Arun,
Can you check if there are any free nodes exists in your model?
Run a normal modes analysis and check if there are any rigid body modes.
