Hi George,
I try to do a single solid element experiment to test out different material properties, ect. However, I struggle to setup the experiment boundary conditions. When I use a setup where I fix the lower nodes in all 6DOF and apply a force on the top ones (see the image) than I restrict the lower nodes and prevent them from any lateral contraction. On the other hand, when I setup my experiment as a beam-experiment I have no possibility to measure the diameter and see if it contracted as expected.
What is the best way to go?
Thanks, J
