I cannot launch PSIM 26.0.0.7209 using my free Altair Student Edition license.
My local license file contains HyperWorksEDU with:
START=2026-04-09
END=2027-04-10
I have tried the following:
- Selected the local .lic file in PSIM License Setup.
- Set the user environment variable ALM_HHWU=F and restarted PSIM.
- Tested Power Supply and Motor Drive separately.
- Tried activating the existing key again. The result was:
“Error activating license: License already exists in license store.”
PSIM still reports Error Code 9, “Feature not found,” for either PSIMPowerSupplyFeature or PSIMMotorDriveFeature.
Before setting ALM_HHWU=F, I also received Error -29:
“Requested CT/TTF license not found for given customer ID.”
Could you please help verify whether my installed PSIM version and student license are compatible, and advise how to restore access?
Could this be related to the current Altair One maintenance?
Thank you.
