학생 라이센스 코드를 입력하면 이미 활성화되어있다고 하는데
라이센스 파일을 휴지통에 삭제시켜버려서인지 deactivate를 하지 못하는 상황을 겪고있습니다.
혹시 해당 문제를 해결하거나 라이센스를 deactivate시켜주실 수 있으신가요?
Product: Altair PSIM 2026 Student Edition
Your license key has been deactivated in Altair One, and you can now reactivate your student license using the same key.
Kindly note, The Altair Free Student Edition license is valid for use on only one device, it cannot be shared or activated on multiple machines at the same time AND Deactivation and reactivation feature is only if a computer breaks down or reformatted and is only allowed a few times per user preprogrammed into the system.
You can deactivate the license from one machine and reactivate in another by yourself if you have access to both machines as per – https://community.altair.com/discussion/34280/altair-student-edition-deactivate-from-one-computer-to-activate-in-another-in-the-rare-case-a-computer-is-lost-or-malfunctional#latest
Thanks
