I have two surfaces in contact and want to add the friction contact pair between rod cap and connecting rod: the red and yellow surfaces
I have meshed my component and when running the job I get the following error message:
***WARNING: SOLVER PROBLEM. NUMERICAL SINGULARITY WHEN PROCESSING NODE 1485
D.O.F. 3 RATIO = 10.E+12 .
CONTACT PAIR (ConnectingRodSurfaceContact,ConnectingRodCapSurfaceContact) NODE 184040 IS
OVERCLOSED BY 688.940 WHICH IS TOO SEVERE. SPECIFY A LARGE VALUE FOR
THE HCRIT PARAMETER TO IGNORE SEVERE OVERCLOSURES.
CONTACT PAIR (ConnectingRodSurfaceContact,ConnectingRodCapSurfaceContact) NODE 184051 IS
OVERCLOSED BY 610.788 WHICH IS TOO SEVERE. SPECIFY A LARGE VALUE FOR
The simulation is terminated due to diverging solutions but I do not understand how the overlosure is so large, since in the component assembly they are already in contact.
I have tried checking the penetration and intersection in hypermesh but autocheck results in no change (i.e as soon as I re-check, the intersection erros are still present) but interestingly enough no penetration!
If anybody has experience in such situations I would be truly greatful as I have no clue how to move forward since the same error messages appear for the left contact analagous to this one.
Kind regards!
