Hello everyone,
I am new to Altair SimLab 2026 Student Edition and currently trying to perform a CFD simulation using AcuSolve.
I imported a STEP model of a microfluidic chip with an internal serpentine channel and successfully created a CFD mesh. However, when setting up the CFD analysis, I encounter the following issues:
- Boundary Conditions remain unavailable or cannot be properly assigned.
- When creating an Inlet, SimLab displays:
"Please select faces from solution: Flow_1" - Running Data Check results in:
"No bodies present in solution. Data check failed."
The geometry contains an internal serpentine channel intended for fluid flow. I suspect there may be an issue related to fluid domain creation or body assignment to the Flow solution.
Could anyone advise:
- How to verify whether the fluid domain has been correctly created?
- How to assign the fluid body to the CFD solution?
- Whether there are any limitations in SimLab 2026 Student Edition regarding CFD setup?
Thank you.
