I need to change my account type for "Everyone Else". I created a student account for FSAE, but my team has a company license.
@BernardoGarrett
Your account is already verified as student and eligible to use the student edition. Please refer to the following guide for detailed instructions on installing and activating your Altair Student Edition software using your Student Edition license key -
I can see that your uni has academic licenses (managed licensing) as well. If you want to disconnect from the managed licensing, please set an environment variable with name ALM_HHWU and value F to disconnect from managed licensing and use the student edition license. You can set it to T to use just the managed licensing. Once done please use either just the free student edition license or the managed licensing activation methods.
Since you registered as a student, you cannot be moved to the “Everyone Else” category using the same email unless removed completely from the system and then you register again with “Everyone Else” category.
Thanks
