I installed Simlab 2026 from the Altair marketplace. After installation, the tool worked and I was able to import my design then mesh it. I saved my progress for the day. The next day when I tried to open the tool again, the Simlab window opens for a second and then the program crashes. On investigating further, I see that the OPENGL.DLL was the reason behind the crash. In an attempt to resolve the issue, the environment variable QT_OPENGL was set to "software". Still the problem persists. As per my knowledge, the GPU driver is also update.d Can someone please help me, I have been stuck with this issue for quite so time.
