Altair Embed SE 2025.2 Build 14
Log file attached.
Fresh install to see if something was broken on the previous install.
Amutil indicates the license is working, but something is corrupted or locked up.
I found this post:
SOAP 1.1 fault SOAP-ENV:Client [no subcode] "End of file or no input: message transfer interrupted or timed out (5 sec max recv delay) (5 sec max send delay)" - Altair Community
But that user variable does not exist.
i've tried everything i can. I thought the fresh install would certainly fix it. I'm wondering if this is on the server side.
i've deleted the user account and started a new one with the same credentials.
and a new one with different credentials.
Really stuck now.
