Hello all,
I'm getting this error lately in HyperLife for weld certification.
For this specific file when I try load the Model and Results file in hyperlife weld certification, I am getting this error called
" Result Import has experienced an issue - aborting process " and in the status bar I can see this " *set value : Could not modify the value of dataname/attribute : int ".
The hyper life is working well and good for all the files, its used to work for this file also but just now i'm getting this error for this specific file.
The *h3d file is working well, I can see the results in hyperview
