I am facing Ticket Number : #100.18.11 #100.18.10 #100.18.1 #100.18.39 error.
Hello
Can you please add more details to your question like product as minimum.
Hello Jason, thanks for the reply.
this error code is from the Product Flux Motor.
Hi Jit,
Thank you for mentioning the product. Can you please let us know what is the test you performed and type of motor? is it skewed?
I recommend to share the error zip file, here in forum the shared files are visible to everyone, i suggest you to raise a support case and upload the file there.
Thanks
Hello Karun, its simple induction motor , I tried all four simulation but none worked. attaching zip file for your investigation, TIA.
Best regards
Jit
one more file is here
