I am trying to run a composite optimisation in Altair HyperMesh 2026 using the Optistruct solver. I get results for the first iteration, but the solver doesn't do any optimisation and stops the analysis after the license check fails. I am getting the following error. In the license file, I only have features HyperViewTrans, HyperWorksEDU and romAI. Hypermesh works perfectly fine and checks for the EDU license, whereas the Optistruct solver does not.
License error:Altair License Manager: License errorFeature(s): GlobalZoneEU, HyperWorks, HWOptiStructFEAError Code: 9Error Description:Feature not foundFeature: OptiStructFEAError Code: 9Error Description:[LOCAL] D:/PLM/Altair/2026/security/altair_lic.dat - (Err: 9) Feature not found
The .dat file is attached: "model_sim1-solution_2.dat". It is a simple composite specimen for free-size composite optimisation.
Thank you in advance for the help.
Best regards
Martin
