I hope these problems will be solved soon.
Best regards.
Hello, Thanks for reaching out. 1. If you are talking about using Current formula with Angular position for imposed current coil in transient Magnetic simulation, yes its not possible for you to parameterize current with respect to Angular position. Imposed current coil are case of of multi-stranded coil with simplified representation, suitable for simple use cases: In this case, the Joule losses are not computed. Varying current with respect to Angular position doesn't fall under simple use case. Please use circuit, defined by coils .
2. Result request button, is used request the output responses you wish to see after simulation is one. I don't think the crash linked to result request and circuit alone. Can you please create a support request through siemens support center and attach the project in the support request, for us to take look at it. Note: Please don't share any project here, as the community page is publicly accessible to other users. Hope this is helpful. Thank you, Charishma Modem
