I'm using the student version of Altair SimLab and I'm trying to create a co-site interference simulation. So far I've followed along with the official Antenna Placement and Cosite Interference tutorials:
Antenna Placement
Co-site Interference
The problem I have is that I'm stuck on creating a Cosite Interference solution. In the tutorial, the solution dialog has several options that I'm missing, including the field where you select an antenna placement solution. I have an antenna placement solution that works, but I have no option to select it, which means I cannot create a co-site interference solution.
Things I have tried:
- Selecting the antenna placement solution before opening the Co-site interference dialogue (doesn't work)
- Modifying the antenna placement solution into a cosite interference by changing "Type: Antenna Placement" to "Type: Cosite Interference" (seems to cause a weird bug due to a missing XML file that prevents anything from working)
- Downgrading to older versions of SimLab (Co-site interference only seems to be present in version 2026)
- Searched this forum for answers (relatively little info on SimLab exists)
Why do my dialog windows not match the tutorials? And how do I create the co-site interference solution?
