See attached screenshot. I can't capture any of the results I was hoping in a csv format so I can evaluate / compare the model precision and accuracy results. Kindly advise
Hi @d_ice ,
In Automodel, exporting performance is not part of the functionality.
Here is a method by which I found it possible to export the performance matrix. It is a bit involved, but this is what I can offer:
Thank you - this is helpful. ONE OTHER QUESTION. Is there a way to visualize (overlay) histograms by color from two separate projects (one having the real data) and (the other having the synthetic generated data)? I am trying to see the distribution and match to accuracy
Hi @d_ice , sorry I had lost track of this. If we are still talking about Automodel, no I'm afraid you can only select a single data source.
When you refer to a Project, do you mean a data table of some sort?
thank you for the assistance here.
I have another question How can rename Metric_Code to actual attribute names like replace 1 with age, 2 with height…..through 8? it does not seem like there is graphing change capabilities and I have to go back into the code which will mess up numbered values for the equation.
Sorry I would need a bit more context.
