One bar should give about 10N at 4cm compression in abaqus.
However, after I imported it into simlab, SPC force results in 3kN.
I also made material test using simple cubic or dumb bell, they has same behaviour in material test.
What is causing the high stiffness of simlab model?
There must be some hidden structural or elemental difference.
