I am using the Altair Student Edition license.
I followed all instructions from the official Altair Student page:
- Registered and verified my academic email
- Generated the activation key
- Installed HWDesktop 2025.1
- Installed HWsolvers 2025.1
- Activated the license successfully using Altair License Utility
HyperMesh launches correctly and works without any issues. I can create and edit models normally.
However, when I try to run OptiStruct (by submitting a .fem file from HyperMesh), the solver fails with the following message:
ERROR WHILE CHECKING LICENSE !Solver FAILED
In some cases I also received CUDA-related DLL errors (missing cublas64_12.dll / cusparse64_12.dll), which I resolved by installing CUDA 12.x. After that, HyperMesh works normally, but OptiStruct still fails during license checking.
Could you please advise why OptiStruct is failing with a license check error, even though HyperMesh is working correctly?
Thank you in advance.
Best regards,
Karlo
