Hello, what is a material card for Radioss explicit solver if I have a thermoplastic polimer (for ex. PA6+30GF) at different strain rate? As you know the elastic modulus change from quasi-static tensile to higher strain rate, in fact increase.. due to increase the stiffness of the material if I stretch at high velocity. Is possible to use a material card where I insert a total strain curves at different strain rate?
