I am modeling a nonlinear compression spring in OptiStruct using CBUSH + PBUSH + PBUSHT + TABLED1. I want to know how to apply initial compression preload in Optistruct.
My setup (Example):
- Total system has 16 physical wave‑springs.
- In FEA, each physical spring is modeled as 1 CBUSH element, so I have 16 CBUSH elements total.
- Physical test data (total spring ring):
- Free length spring
- 100 N @ 1 .83 mm compression (Assembled position of springs)
- 162 N @ 3 .23 mm compression (Engaged position)
- Since I have 16 elements, force is divided per element:
- 1.83 mm → 6.25 N per element
- 3.23 mm → 10.16 N per element
I have modeled springs in engaged position.
Can anyone explain about how should i create spring properties for this. my load is applying pressure on Piston plate.
