I have a simple model bolted joint, I need bolt forces as per VDI2230 standard. As per VDI2230 guidelines model II I designed the model with preload in the bolts and contact interface, I modelled the bolts with PBeam element and requested ELForces at the bolt sets, the axial forces of the bolts is equal to the preload applied.
I did another iteration without preload the axial force differed.
Shouldn't it the case where due to external loads the preload should reduce or increase.
