Hi there - I am unable to use the visualizations section of AI Studio on a Mac due to an error with HTML5. I think this is because the software comes bundled with Java 17, which I have researched to find is not compatible with the HTML5-based Visualization tab, so I am unable to view any visualizations directly within the application. However, the data processing workflow runs correctly, and all outputs are generated as expected. I tried to install Java 11 but it won't override Java 17 in the educational version. Any suggestions?
