I am trying to simulate a tracked vehicle on a rigid (non-deformable) road in MotionView. I have set up my vehicle using the process given in the Tracked Vehicle Modeling tutorial (link: Tracked Vehicle Modeling) but diverge from the tutorial at the 'Soil Interaction' step (step 3.10).
Here, I use the 'Rigid Contact' option with a meshed flat ground created in HyperMesh, however, the mesh does not carry over to MotionView. Instead, it is replaced by a much coarser mesh, which (I suspect) results in the following error when I try to run the simulation:
"MotionView(General) Error: Contact "TrackLeft Contact Terrain 0" under "Model-Suspension-TrackLeft" references one or more graphics that contain free edges, i.e. the geometry is not closed, or T connections. The graphic(s) in question are: Terrain Graphic. Open shell graphics or graphics with T connections are not allowed in contact simulations."
Please find images of the meshes below:
From HyperMesh - Whole Road
From HyperMesh - Close View
From MotionView - Whole Road
Any help in fixing this issue is appreciated.
Thanks
