Hello!
I need to carried out a CFD simulation and I'm using SimLab v2025.1. I've imported the mesh in the program, but I've a problem with the application of the boundary condition.
For convenience, I created a very simple model (Cavity), which has the same problem. It is a simple box (screenshot), the inlet face is the selected one in pink. I need to split this face in two separately selectable faces, because I've to apply different boundary condition (in theory it is already possible to see the two faces distinctly because they are marked by thicker lines).
I've try to use the command "Split face" and "Break face" in the "Geometry" ribbon. But with the first it is impossible because it's a planar face, so I can't use "split by angle". With the second command, I've this error: "Not supported for volume body."
Does anyone know how to do this?
Thank you very much for your time and support.
