I am experiencing somewhat chaotic behaviors when exporting solver decks both through HyperWorks and Hypermesh interfaces. In both cases the outcome is identical. Here is the situation: I am having trouble exporting node sets to a solver deck file (.fem as I am using optistruct solver). I verified that the sets are activated and that the export option is checked for the set in the entity browser. I also tried using the "all" option under the export options but whatever I did the set was never exported in the resulting .fem file. You will find the original .hm file, the .fem file exported when "all" option is used for export, as well as screenshots below.
The expected paragraph in the .fem file is the following:
Exporting with "all" option:
Any idea how to fix this export problem ?
Thanks !
