There is a difference in results between Hypermesh and Hyperview.
I am extracting stresses in material system in hypermesh. Then I export results in Hyperview in material system.
There is a difference upto 3-5% difference for some elements.
Iam extracting results for elements with composite property.
Does anyone face similar issues?
Please let me know.
can you add a couple images of what are you facing?
And also the options that you're using in both cases?
0 -
Steps I followed in Hypermesh:
1. Open HM model.
2. Aerospace > Results > File loader > [Select OP2 file]
3. Aerospace > Results > Results Query > Start
4. Please refer the image1 below for rest of the options i followed.
Steps I followed in Hyperview:
1. Open .bfd and .op2 file in hyperview
2. Please refer the below image2 for the next options.
One check i did, comparing Hypermesh and Hyperview:
Element results in Element coordinate system is matching correctly.
This issue of mismatch I notice only for material system.
Also this issue exists for 2D force, 2D moment, 2D stress.
It would be helpful to know what is the angle hyperview/hypermesh uses for transformation of stress/forces.
