Hello everyone,
I have a question about a simulation using Compose 2025.1 and PSIM 2025.1.
I have a very simple PSIM file that simulates a constant DC voltage source and a resistor. I use "parameter sweep" in my PSIM file to vary the resistance value from a minimum to a maximum value in three steps.
If I use only PSIM, the simulation works correctly. i have three current value in SimView.
I try to run the same simulation with Compose, and the simulation only runs for the first step.
There are no variations in the resistance value. Only one simulation!
I've attached both files in case anyone has any ideas.
Thanks for advance
Patrice
